Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace your 12 pin connector if it is damaged and does not charge properly. When replacing the component, use a Phillips #1 screwdriver and iFixit Opening Tools to proceed with the replacement.
Выберете то, что вам нужно
Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
Flip over the SmartFeeder by using both hands.
Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
Place the bottom piece of the device right-side up.
Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
