Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
Remove the metal tray by using both hands and pulling out the bowl towards you.
Turn the bowl tray side down by using both hands.
Remove seven 11 mm screws by using the Phillips #1 screwdriver.
Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
Remove the tape, closest to the four white connectors, with your hands.
Trace the wires with your hands from the battery to the motherboard.
Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
Еще один человек закончил это руководство.
