Petzl E03 050 Headlamp Light Bulb Replacement Guide
  1. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Check For Spare Bulb: шаг 1, изображение 1 из 1
    • Check for a spare bulb in the spare bulb compartment located on the back of the battery housing (found behind the mount assembly). If no spare bulb is found in the spare bulb compartment you will need to purchase a replacement 3V incandescent bulb from a reputable retailer
  2. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Loosen the Lens Piece: шаг 2, изображение 1 из 1
    • Turn the lens piece counterclockwise (left) until it is fully extended.
  3. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lens Piece: шаг 3, изображение 1 из 1
    • Remove the lens piece by firmly pulling it away from the battery housing.
  4. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lightbulb: шаг 4, изображение 1 из 1
    • Turn the bulb counterclockwise (left) until it becomes free. Safely discard the old bulb.
  5. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Install the New Lightbulb: шаг 5, изображение 1 из 1
    • Install the new bulb by inserting it into the socket.
  6. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Rotate Replacement Light Bulb: шаг 6, изображение 1 из 1
    • Rotate the bulb clockwise (right) until it is firmly fixed in place.
  7. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Re-attach the Lens Piece: шаг 7, изображение 1 из 1
    • Press the lens piece onto the front of the battery housing.
  8. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Tighten the Lens Piece: шаг 8, изображение 1 из 1
    • Turn the lens piece clockwise (right) to the “On” position. If the light fails to illuminate after turning the lens piece to the “On” position you may have to replace the batteries.
Финишная прямая
Carla
Участник с: 10/19/14
131 Репутация
1 руководство автора
Команда
Baylor, Team 8-10, Williams Fall 2014 Участник Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 членов
Автор 10 руководств
3 Комментарии к руководству
Ha I wonder how many people don’t even realize there’s a replacement readily available on their head! Thanks for sharing.
jmania - Ответить
This was my father headlamp. Want to continue using it.. makes me feel like he is this with me
laura.odonnell52 - Ответить
Is it also possible to replace the old 3v light bulb with an LED light?
bertkling - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 23
За последние 30 дней: 96
За всё время: 5,961
