Введение
Follow the procedure outlined in this guide to remove and install the circuit board for the device's bottom buttons.
Запчасти
Никакие детали не требуются.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
      • Electrical Connectors
      • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  7. Pull the board out from the dock
    • Pull the board out from the dock
Заключение
Greg Lane
Участник с: 16.04.2013
9 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 3-48, Amido Spring 2013 Member of Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 членов
Автор 6 руководств
Один комментарий
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 8
За 30 дней: 9
За всё время: 645
