Введение
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
Выберете то, что вам нужно
Pry off the four white feet with the pointed end of the spudger
Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
