Введение
Follow the procedure in this guide to remove and install a broken LCD screen.
Выберете то, что вам нужно
Pry off the four white feet with the pointed end of the spudger
Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
Slide the back panel towards top of the device and lift away from the device to detach back panel.
Unscrew the seven 6 mm Phillips #00 screws holding the grey side piece to the black front panel.
Unscrew the two 8 mm Phillips #1 screws that go through the grey piece and the LCD motherboard.
Remove the ribbon cable from the ZIF connector by pulling out the two black tabs with the pointed end of the spudger then pulling the cable straight out of the connector.
Remove the grey side piece from the black front panel by pulling it straight up. It should easily slide off.
Unscrew the six 8 mm Phillips #1 screws holding the LCD screen to the black front panel.
Unscrew the two 6 mm Phillips #00 screws from the top of the panel holding the the LCD screen to the front panel.
Pull the LCD and circuit board off of the front panel.
