Введение
Follow the procedure outlined in this guide to remove and install a speaker.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  7. Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel.
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  8. Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  9. Slide the speaker towards the bottom of the device to remove. Slide the speaker towards the bottom of the device to remove.
    • Slide the speaker towards the bottom of the device to remove.
Заключение
Graham Rolph
Участник с: 18.04.2013
1 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-48, Amido Spring 2013 Member of Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 618
