Введение
In this guide, we are going to detach the disc tray from the device.
Выберете то, что вам нужно
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
Remove two 7.5 mm screws, one on each side of the player.
Remove three 7.5mm screws from the bottom of the player.
The first 3 ribbon wires can be removed by grasping near the head and gently pulling up.
Locate the skinny fourth ribbon wire near the top right of the motherboard.
Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
Remove the 12 mm Phillips screw that secures the tray to the upright metal frame.
Remove the two 7.5 mm Phillips screws that attach the disc tray to the motherboard and front panel.
Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
6 участников успешно повторили данное руководство.
3 Комментариев
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
I failed huhuhu
