Введение
In this guide, you will locate several screws that hold the top panel in place and remove them. They are all Phillips screws and are simple to remove.
Запчасти
No parts specified.
  1. Remove four 7.5 mm Phillips screws on the both sides (2 on each side). Remove five 7.5 mm Phillips screws on the back of the player.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
Заключение
3 участников успешно повторили данное руководство.
Nathan Klammer
Участник с: 06.10.2011
299 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 838
