Введение
If your CoughAssist ventilator is acting up and not working correctly, the first step to replacing parts is always disassembling the main unit. This guide will allow you to start repairing almost any part within the ventilator.
Выберете то, что вам нужно
First, remove the two 16mm pan head screws (1) directly under the front panel of the ventilator. (Page 3).
Next, remove the two 16mm flat head screws (3) from the back panel of the ventilator. (Page 3).
Now remove the "Inhale flow" control knob (4) and "Inhale pressure" knob (4), by loosening the setscrew on each before pulling off. If you have a CM model, carefully remove the Manual Control Lever (3) by prying it off with the screwdriver. (Page 3).
Unscrew the three 12.7mm plastite screws ( 2) holding the panel assembly to the lower housing. A long Phillips screwdriver is very helpful for access to the three screws. (Page 3)
The front control panel (5) should now be loose. Carefully slide it forwards to remove. (Page 4).
