Введение
When the battery dies completely and no longer holds a charge, this guide will illustrate the proper way of removing the battery for replacement. CAUTION. Please do not throw away the dead battery in the trash. See a proper disposal center for any handling of dead batteries.
Выберете то, что вам нужно
Hold trimmer towards you as shown in the diagram.
Insert your prying tool/metal spudger into the marked area.
Apply gentle pressure and begin prying open the back panel.
Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
Pull the trimmer apart using your hands once the panel is at least halfway apart.
Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
Apply gentle pressure and begin prying the front panel.
Separate the front panel one notch at a time.
Face the battery towards you.
Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
29 участников успешно повторили данное руководство.
20 Комментариев
Hi, what are the specs on the NiMh battery?
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
I think you can simply use a AA battery, 1.2V
Note: AA Alkaline battery is 1.5V and not rechargeable.
Awesome work.very helpful
