Выберете то, что вам нужно
Hold trimmer towards you as shown in the diagram.
Insert your prying tool/metal spudger into the marked area.
Apply gentle pressure and begin prying open the back panel.
Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
Pull the trimmer apart using your hands once the panel is at least halfway apart.
Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
Apply gentle pressure and begin prying the front panel.
Separate the front panel one notch at a time.
Remove the front panel completely from the rest of the beard trimmer.
Push the white plastic frame upward to remove it from the notch.
Pull the white plastic frame off the front panel of the beard trimmer.
Remove the power switch from the front panel once the white plastic frame is removed.
