Введение
This guide will show you how to remove the casing in order to access the battery and motor.
Выберете то, что вам нужно
Grip the attachment and twist it counterclockwise until you hear a click.
Pull the attachment up to remove it from the trimmer.
Hold the trimmer upright so it is facing you.
Insert the plastic opening tool in the gap at the top of the power button.
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
Pull upward on the top of the inner housing to remove it from the outer casing.
9 участников успешно повторили данное руководство.
