Philips PD9000 37 White Outer Housing Replacement
Выберете то, что вам нужно
  1. Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: шаг 1, изображение 1 из 3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: шаг 1, изображение 2 из 3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: шаг 1, изображение 3 из 3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Philips PD9000 37 White Outer Housing Replacement: шаг 2, изображение 1 из 2 Philips PD9000 37 White Outer Housing Replacement: шаг 2, изображение 2 из 2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 White Outer Housing Replacement: шаг 3, изображение 1 из 3 Philips PD9000 37 White Outer Housing Replacement: шаг 3, изображение 2 из 3 Philips PD9000 37 White Outer Housing Replacement: шаг 3, изображение 3 из 3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 White Outer Housing Replacement: шаг 4, изображение 1 из 3 Philips PD9000 37 White Outer Housing Replacement: шаг 4, изображение 2 из 3 Philips PD9000 37 White Outer Housing Replacement: шаг 4, изображение 3 из 3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
Заключение
Julia Sheremet
Участник с: 09/28/15
303 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-3, Matresse Fall 2015 Участник Eastern Washington University, Team 1-3, Matresse Fall 2015
EWU-MATRESSE-F15S1G3
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 466
