Введение
An 8-mm socket wrench with extension is required. For more information on replacing the oxygen valve, please refer to page 9-74 of the service manual.
Выберете то, что вам нужно
Before replacing the oxygen valve assembly:
You must install the oxygen regulator assembly before reinstalling the oxygen valve assembly
When reinstalling the oxygen valve, make sure the oxygen regulator and oxygen flow sensor are fully installed to the oxygen valve assembly
Always inspect the O-rings between interconnecting parts, and replace them if they are visibly damaged or rough to the touch.
Always use new O-rings supplied with replacement parts
Lightly lubricate O-rings with Krytox GPL226 lubricant when installing, and relubricate at every reinstallation
Remove the oxygen flow sensor
(Instructions found in Chapter 10.26 of the Respironics V200/Esprit Ventilator Service Manual.)
Careful! Do not cut the tie wrap or disconnect the O2 F/S cable from the flow sensor.
Remove the air flow sensor
(Instructions found in Chapter 10.27 of the Respironics V200/Esprit Ventilator Service Manual.)
Careful! Do not cut the tie wrap or disconnect the AIR F/S cable from the flow sensor.
Remove the air valve assembly
(Instructions found in Chapter 10.30 of the Respironics V200/Esprit Ventilator Service Manual.)
Disconnect the two MTR O2 cables on the oxygen valve from the mating MTR O2 cable
Using a 8-mm socket with extension, remove the three bolts that hold the oxygen valve bracket
