Philips SBA1060 Circuit Board Replacement
Выберете то, что вам нужно
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: шаг 1, изображение 1 из 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: шаг 2, изображение 1 из 3 Philips SBA1060 Circuit Board Replacement: шаг 2, изображение 2 из 3 Philips SBA1060 Circuit Board Replacement: шаг 2, изображение 3 из 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: шаг 3, изображение 1 из 2 Philips SBA1060 Circuit Board Replacement: шаг 3, изображение 2 из 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: шаг 4, изображение 1 из 1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: шаг 5, изображение 1 из 2 Philips SBA1060 Circuit Board Replacement: шаг 5, изображение 2 из 2
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
Заключение
2 участников успешно повторили данное руководство.
April Driscoll
Участник с: 10/21/13
321 Репутация
Автор 3 руководств
Команда
Clemson, Team 14-4, Benson Fall 2013 Участник Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 членов
Автор 4 руководств
2 Комментариев
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - Ответить
Nice picture,it helps a lot in trouble shooting !
sergio - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,302
