Введение
This guide will teach how to disassemble Phillips Satinelle for parts replacement
Выберете то, что вам нужно
Unplug the device and remove the purple guard.
Remove the head by pressing the right side of the head (with the device facing away from you).
You will hear a 'click' and the head will become dislodged from the body of the device.
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
Be careful not to lose the clip. It will likely fly off when it releases.
Инструмент, используемый на этом этапе:Tweezers$4.99
The left side will swing down.
Remove the Tweezers.
Remove the plastic component that swings down.
Use fingernails to lift clips from stubs.
Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
6 человек успешно провели ремонт по этому руководству.
6 Комментариев
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
To open main body …Click here
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
