Введение
If the epilator is plugged in and receiving power, but still will not turn on, one of the internal components may be broken. This guide will help you remove a broken motor of your Philips Satinelle. It should take no more than 30 minutes to complete this guide.
Выберете то, что вам нужно
Pull the plastic casing apart with your hands.
That means once the epilator is opened, the same cover cannot be used to enclose the machine??
Hold the motor with the gears face away from you.
Gently push the motor out with your thumbs.
Еще один человек закончил это руководство.
