Введение
Consumers have encountered heating problems with the Philips Senseo II 7810. Numerous issues that cause the coffee maker to not heat up water anymore can be: problems that prohibit engaging the heater element, a failing heater element or the machine shutting down early. The latter is mostly due to a capacitor that is not working properly and seems the most common issue. It can easily be recognized when the machine shuts down during the making of the coffee. Over time, degrading of the capacitor will happen and thus the problem is inevitable in the longer run.
This guide enables you to replace the described capacitor, and to repair your coffee maker. Using the same repair steps, it is also possible to replace the PCB's TRIAC and E-cap. These replacements are recommended when performing the capacitor fix.
This repair guide can also be suitable for other Philips Senseo models. Making the repair can lengthen the lifespan of your Senseo coffee maker. In this case, capacitor failure does not have to result in product failure, and by performing the repair the Senseo still holds its value.
Выберете то, что вам нужно
Remove the detachable components of the coffee maker:
unplug the product;
empty the water container and remove it from the coffee machine;
remove the cup tray and drip tray;
remove the pod holder and coffee outflow unit.
Remove outflow valve by putting a flathead screwdriver in the gaps and use this as a lever.
Remove back panel by:
inserting (flathead) screwdriver in the top and pressing this against the snap-fit;
pressing screwdriver on left side against the snap-fit simultaneously;
rotating back panel whilst pressing against the snap-fits to loosen the panel until it is no longer connected on that side;
pressing screwdriver on right side against the snap-fit and removing back panel altogether.
Remove side clamps to make the boiler accessible by pressing the plastic hooks (left and right) to the side.
Access the inner housing of the coffee maker by:
removing tie wrap from three-way valve with a pair of scissors;
disconnecting the three-way valve from the hose. Beware of possible breaking of the bottom tube of the valve that is inside the boiler opening;
tilting the boiler, towards you (away from the inner casing).
Tilt the coffee machine and disconnect the bottom housing by pressing a flathead screwdriver against the snap-fit (CAUTION). There is a total of 6 snap-fits. (Two snap-fits at the rear are not visible in the picture)
Remove the cylindrical housing from the bottom housing.
Remove the cup tray housing from the bottom housing.
Disconnect the two cables (white-brown) from the red pump by pulling gently. If the cables are hard to remove, carefully use flat nose pliers to pull the cables.
Disconnect the red, blue and green/yellow cables from the boiler.
Remove the two white cables, so the printboard (PCB) is no longer connected to the internal components.
Remove the nut from the plate against the PCB, using a Phillips screwdriver.
Remove the snap-fits of the PCB, so the plate and the PCB can be disconnected. Use a flathead screwdriver for punching and sculling.
Search for the pegs of the capacitor on the PCB and warm up the soldering iron. Remember orientation (left-right)!
De pijl wijst naar een kleinere C van 100nF. De grotere is 470nF.
Bij mij was overigens de elco (zwarte ronde cilinder met metaal-glimmende bovenkant) kapot. Deze is 470muF-16V. Alhoewel er niets aan te zien was wel kapot. Makkelijk vast te stellen doordat de elco een kortsluiting was, wat je met elke multimeter vast kan stellen. Normaal gedrag is gedurende 1 tot enkele seconden "geleiding" (condensator laadt op) en dan oneindige weerstand. Bij mij vormde de elco een kortsluiting. Let bij vervanging op de polariteit, een elco heeft een + en een -!Succes met repareren!!
Loosen the capacitor of the PCB, by desoldering the tin spots using the iron and remove the capacitor from the PCB.
Replace the capacitor by soldering a new capacitor of the same type on the exact same spot:
scratch the green plastic of the printboard (with flathead screwdriver) to improve conductivity and cohesion;
keep the capacitor on the right spot, hold the tin against the pegs of the capacitor and heat the tin with the soldering iron. The tin will cool down and the capacitor will be fixed.
Reassemble the Senseo coffee maker. The suggested actions during the disassembly should now help you greatly. Be careful with connecting wires (in the right way), tilting and reconnecting the boiler, and closing the housings and snap-fits.
In other senseo 7810 models things may look a bit different, but it will work nevertheless.
Thank you from repair-cafe Neuburg/Germany
Can I change the capacitor from 240vac to 110v? In mine as I have a 110v supply and my machine is 230v?
A higher voltage is not a problem, the reverse is.
VauWeh -
13 участников успешно повторили данное руководство.
2 Комментариев
If the capasitor has been changed and the water still doesn't heat up. What next?
Check the boiler. Can be defective.
