Выберете то, что вам нужно
Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
Use a Phillips screwdriver to remove the screw at the base of the metal head.
9 участников успешно повторили данное руководство.
7 Комментариев
Great guide - but where is a good source for replacement parts?
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
