Введение
This guide will help you replace the spring in your Philips Sonicare FlexCare toothbrush.
Выберете то, что вам нужно
Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
4 участников успешно повторили данное руководство.
