Введение
If the USB-C charging port of your Pine64 PinePhone loses its functionality, you can replace it by using this guide. Charging ports can become damaged from everyday use or obstructions pushed further into the device by the charging cord, but are easily fixed following this guide.
Before beginning, inspect the inside of the port and remove any debris inside. If the phone still refuses to charge, or only charges at certain angles, proceed.
Выберете то, что вам нужно
Place the device face down on a non-scratch surface.
Using a fingernail pry open the back cover off with the bottom left indent.
Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
Remove the battery.
4 человек успешно провели ремонт по этому руководству.
