Введение
If you are looking to replace the antenna of your Pioneer A1 XW-SMA1-K, here is your replacement guide.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
Remove the speaker frame by pulling vertically upwards revealing the motherboard.
Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
Remove the middle frame by pulling upward and vertically.
Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
Flip the motherboard over.
Remove the motherboard by detaching the antenna.
