Введение
Overheating can cause the Pioneer Elite PRO-R06U to unexpectedly shut off during operation. A broken
cooling fan will make it difficult for the media receiver to dissipate heat, and is the most likely cause of overheating. This guide will show you how to replace the power supply cooling fan.
Запчасти
No parts specified.
  1. Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Remove the two 6.5 mm Phillips screws on the back of the device casing.
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
    • To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
  5. Remove the two 6.5 mm Phillips mounting screws at the back of the device.
    • Remove the two 6.5 mm Phillips mounting screws at the back of the device.
  6. Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Lift the cooling fan out of the device.
Заключение
Cody Carter
Участник с: 30.01.2018
1 049 Репутация
Автор 6 руководств
Команда
Baylor, Team S1-G5, Johnson Spring 2018 Member of Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 членов
Автор 6 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
За всё время: 186
