Введение
Water damage or a faulty electrical opponent may make the Pioneer Elite Pro-R06U shut off intermittently or fail to power on. Removing the faulty board and installing a new one should get the receiver back up and running.
Запчасти
No parts specified.
  1. Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Remove the three 6.5 mm Phillips screws on the back of the device casing.
    • Remove the three 6.5 mm Phillips screws on the back of the device casing.
  3. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  4. Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  5. Gently pull upward and unplug cables D4 and D5.
    • Gently pull upward and unplug cables D4 and D5.
  6. Remove the two 7/16 inch Phillips screws to the left and right of the power supply port.
    • Remove the two 7/16 inch Phillips screws to the left and right of the power supply port.
    • Remove three 5/16 inch Phillips screws from the corners of the board.
  7. Remove the power supply board by pulling it toward the interior of the device then lifting.
    • Remove the power supply board by pulling it toward the interior of the device then lifting.
Заключение
Cody Carter
Участник с: 30.01.2018
1 049 Репутация
Автор 6 руководств
Команда
Baylor, Team S1-G5, Johnson Spring 2018 Member of Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 5
За 30 дней: 11
За всё время: 210
