Введение
This guide gives steps to replace the motherboard of the speaker. This part may be need to be replaced if the speaker does not turn on or is not responding to commands.
Выберете то, что вам нужно
Flip the speaker upside down with the back panel of plugs pointed away from you.
Use the metal spudger to pry off the rubber bottom cover. It will be glued onto the bottom of the speaker.
Work the rubber cover off by slowly going all the way around with the metal spudger, applying as much force as needed.
Scrape most of the glue away to reveal the five flathead screws - four around the outside, and one in the middle.
Lift off the metal plate. It will be surprisingly heavy and it is approximately 1cm thick.
Turn the speaker counter-clockwise 90 degrees.
Use a knife to cut along the left seam all the way down the length of the device.
Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you.
Remove one 6 mm screw with a Phillips #2 screwdriver.
Spin the device so the opposite side is facing you.
Remove the two 6 mm screws with a Phillips #2 screwdriver.
Carefully remove the top panel, light ring, button panel, and the corresponding board.
Peel off all rubber strips along sides, middle front and middle back of the device.
Pry apart the two sides carefully. The halves will not be able to separate completely because of wires and the motherboard.
Remove the two wire connectors using tweezers or your fingers. Be careful not to damage the plastic.
Remove the 3 pieces of hot glue using tweezers. Don't worry about ripping the foam covering the cords.
Remove the ribbon wire by pulling on it with tweezers.
Peel away the off white glue and disconnect the wires from the motherboard.
Remove the motherboard from the device.
