Введение
A faulty USB port can cause the user unable to play media to the radio receiver. This guide will show you how to replace the USB port for the Pioneer FH-X730BS.
Выберете то, что вам нужно
Apply pressure to the tabs on each side using the plastic opening tool.
You will need to pull the face away from the frame while unhooking the tabs.
After removing the stereo face from the frame it should look similar to this.
Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
You can now insert the replacement audio buttons into the face.
Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
