Введение
This guide shows how to replace the metal sleeve on the Pioneer MXT-X366BT. This guide can act as a prerequisite for replacing the internal components of the radio, although the metal sleeve is also available as a replacement part.
Note: The radio must be removed from the vehicle for this guide. If the radio is currently installed in the vehicle, removal may require special assistance.
Выберете то, что вам нужно
Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
Pry the top clip with the plastic opening tool to release it.
Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
Remove the metal backing that is now free.
Еще один человек закончил это руководство.
