Pioneer R1 Touch Screen Replacement
Выберете то, что вам нужно
  1. Pioneer R1 Touch Screen Replacement, Touch Screen: шаг 1, изображение 1 из 1
    • Insert your plastic spudger in the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Touch Screen Replacement: шаг 2, изображение 1 из 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Touch Screen Replacement: шаг 3, изображение 1 из 1
    • Remove the tape that is holding the motherboard to the display and covering the cable attachments.
    • Peel back just the end of this tape to free the front facing camera.
  4. Pioneer R1 Touch Screen Replacement: шаг 4, изображение 1 из 1
    • Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
  5. Pioneer R1 Touch Screen Replacement: шаг 5, изображение 1 из 1
    • Disengage the two cable locks using your spudger or your finger nail.
    • Slide the cable free from the disengaged lock.
    • Do not pull across the cables as this may tear and permanently damage it.
  6. Pioneer R1 Touch Screen Replacement: шаг 6, изображение 1 из 2 Pioneer R1 Touch Screen Replacement: шаг 6, изображение 2 из 2
    • Insert your spudger between the LCD display and the touch screen.
    • Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
  7. Pioneer R1 Touch Screen Replacement: шаг 7, изображение 1 из 1
    • Once disengaged, remove the LCD display from the touchscreen.
Заключение
Christopher Rosario
Участник с: 02/17/15
411 Репутация
Автор 4 руководств
Команда
San Diego State, Team 1-1, Sheppard Winter 2015 Участник San Diego State, Team 1-1, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G1
3 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 2,581
