Введение
This guide will show you the steps to remove the folding hinges at the bast of the headband.
Выберете то, что вам нужно
Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
With force, pull upwards.
Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
Repeat on the opposite side and the headband will be released.
While holding the base of the headband with one hand, hold the ear cup with the other hand.
Pull them apart to reveal the screw.
Loosen the plastic cover piece that protects the chrome folding hinge.
Remove the plastic cover piece.
Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
Repeat for the opposite side if necessary.
