Введение
This guide will show you the steps to remove the headband.
Выберете то, что вам нужно
Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
With force, pull upwards.
Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
Repeat on the opposite side and the headband will be released.
