Введение
The guide will take you through the process of replacing a dead or defective battery in a Pipo Smart S1 tablet.
Выберете то, что вам нужно
Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
Gently pry the body of the tablet and pop the back cover open.
Lift the back cover of the device and place it on the side.
Lift the white tape with your fingers, then lift the yellow tape that holds the battery extension.
On the bottom of your tablet, use the Phillips #0 screwdriver to take the two 3mm screws out.
Lift the headphone jack and move it to the other side, placing it on the surface you are working on.
Lift the battery and place it a little further away from the positive and negative battery wires.
