Введение
Sometimes, the O-ring seals in the Etha's bolt can get worn out and need to be replaced. Fortunately, Planet Eclipse designed this part of the marker to be taken apart and put back together with ease.
Выберете то, что вам нужно
Grab the flat surface shown.
Unscrew this portion counter clockwise to remove it.
Grab the O-ring on the sides.
Pinch the O-ring upwards to create a gap between the metal and the ring.
Use a small object to slip into the loop and pull the O-ring off gently.
Еще один человек закончил это руководство.
