Введение
The trigger on the Etha doesn't break often, but you may choose to replace it for a trigger you prefer or it may simply need cleaning.
Выберете то, что вам нужно
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Flip the marker over and use the 5/64" hex key to remove the screw shown.
Carefully remove the 9V battery and connector.
Remove the 9V battery from the connector.
Еще один человек закончил это руководство.
