Введение
This guide will show how to replace the solenoid in the Geo3 if it has become nonfunctional.
Выберете то, что вам нужно
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Pull the grip through the opening.
The grip is connected in the middle and is one piece.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
Remove the solenoid.
Pry the board connection with the 2 black wires from the terminal.
Pull out the wires through the opening in the top of the grip and replace the solenoid.
