Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: шаг 1, изображение 1 из 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: шаг 1, изображение 2 из 2
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
  2. Plantronics CS50 Headset System Reset: шаг 2, изображение 1 из 1
    • Press the call control button again.
  3. Plantronics CS50 Headset System Reset: шаг 3, изображение 1 из 2 Plantronics CS50 Headset System Reset: шаг 3, изображение 2 из 2
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
Финишная черта
3 участников успешно повторили данное руководство.
Joe
Участник с: 04/12/12
99 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 17-29, Amido Spring 2012 Участник Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 членов
Автор 7 руководств
4 Комментариев
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Ответить
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Ответить
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Ответить
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 57
За всё время: 22,280
