Введение
This guide will teach you how to install a new case on your HP Photosmart 935 camera. If your camera case is cracked or starting to come apart, this guide will help you replace it with a new one.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
Once the bottom of the inner camera is pulled out, pull the device out completely.
