Введение
This guide illustrates common problems you may experience with the plastic tooth zippers in your life, and provides general information on how to best repair the zipper.If you’re not sure what type of zipper you have, check out our Zipper Identification Tool.
For replacement parts or further assistance, contact Patagonia Customer Service.
Before we get started, let's identify the basic parts of a plastic tooth zipper:
Slider
Pull
Stop
Box
Teeth
Zipper Tape
The teeth on this zipper are melted.
This zipper cannot be repaired and needs to be replaced.
The teeth are missing from the zipper.
This zipper cannot be repaired, so the zipper will need to be replaced.
This zipper is missing the zipper box at the bottom of the zipper.
This zipper is missing the zipper stop at the top of the zipper.
Provided there is enough of the fabric around the zipper, which has been clipped in this image for visibility, you can simply replace the stop as shown in our slider replacement guide.
5 участников успешно повторили данное руководство.
Комментариев: 4
What if there's no reason other than one side of the slider came off?
What about if the zipper zips up but the teeth do not keep closed. I.e. zip up the jacket, part of the teeth stay interlocked but from one point on the teeth become undone and do not lock.
I have the same problem as Juan Umana: one tooth at the bottom (beginning) of the zipper is broken off, so the teeth won’t mesh properly and the zipper teeth stay apart. Ideas welcome.
Robin Cunningham
