Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Disconnect all cables from the console and flip the unit over to reveal its base.
Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
Gently lift and remove the fan from its compartment.
Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
Gently lift and remove the battery from its compartment using a spudger.
Locate the IR sensor at the front, right corner of the unit.
Gently detach the ribbon cable connecting the IR sensor to the motherboard.
Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
Gently lift and remove the IR Sensor from its designated slot.
Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
Locate the three ribbon cables connecting the optical drive to the motherboard.
Gently detach the ribbon cables from the motherboard using a pair of tweezers.
Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
Gently lift and remove the motherboard and chassis from the outer shell.
There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
Gently separate the two metal plates from the motherboard.
33 участников успешно повторили данное руководство.
2 Комментариев
نرجو اضافة اللغة العربية
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
