Введение
This guide will walk you through step-by-step on how to properly remove and install the optical drive in the PlayStation 2 Slimline.
Инструменты
Запчасти
Детали не указаны.
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Pry apart the five visible feet from the bottom of the device using a spudger, or your fingers.
The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
With tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side.
10 участников успешно повторили данное руководство.
Один комментарий
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
