Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through step-by-step on how to properly remove and install the optical drive in the PlayStation 2 Slimline.
Выберете то, что вам нужно
Шаг 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Careful: steps 1-7 are sourced from a guide that's marked as in-progress.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
With tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side.
11 участников успешно повторили данное руководство.
Один комментарий
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
