  1. Этот шаг не переведен. Помогите перевести
    Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3. The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. Этот шаг не переведен. Помогите перевести
    Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. Этот шаг не переведен. Помогите перевести
    Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. Этот шаг не переведен. Помогите перевести
    Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. Этот шаг не переведен. Помогите перевести
    Remove the following seven screws:
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. Этот шаг не переведен. Помогите перевести
    Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
  7. Этот шаг не переведен. Помогите перевести
    Use your fingernail to flip up the retaining flap on the control board ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. Этот шаг не переведен. Помогите перевести
    Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. Этот шаг не переведен. Помогите перевести
    Remove the control board from the lower case.
    • Remove the control board from the lower case.
Финишная черта
15 участников успешно повторили данное руководство.
Комментариев: 2
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - Ответить
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 22
За последние 30 дней: 87
За всё время: 45,714
