Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
How to replace the hard drive in a PS3.
Запчасти
Детали не указаны.
  1. Locate the hard drive bay cover on the side of the PS3.
    • Locate the hard drive bay cover on the side of the PS3.
  2. Remove the cover with a spudger. Remove the cover with a spudger. Remove the cover with a spudger.
    • Remove the cover with a spudger.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Lift the metal tab on the hard drive enclosure. Pull the tab to slide the hard drive enclosure to the right. Pull the hard drive enclosure out of the PS3.
    • Lift the metal tab on the hard drive enclosure.
    • Pull the tab to slide the hard drive enclosure to the right.
    • Pull the hard drive enclosure out of the PS3.
  5. There are four screws on the side of the hard drive enclosure. Two of the screws are shown here. The other two are on the opposite side. The screws are very tight. Be careful not to strip them!
    • There are four screws on the side of the hard drive enclosure.
    • Two of the screws are shown here. The other two are on the opposite side.
    • The screws are very tight. Be careful not to strip them!
    • Remove the two screws on one side of the hard drive enclosure with a Phillips #1 screwdriver.
    • Flip over the hard drive enclosure and remove the remaining two screws on the other side.
  6. Carefully slide the hard drive out of the metal enclosure.
    • Carefully slide the hard drive out of the metal enclosure.
    • Note the orientation of the hard drive when sliding it out of the enclosure.
Заключение
4 участников успешно повторили данное руководство.
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Один комментарий
I dont suppose u can do one for a lughtning zapped power bs upply replace me nt all of my gran turismo amd well all games i play ma6be with a upgrade the speed power and make it ps4 with out the crap of online
Audiophile - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,792
