Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace your PlayStation 3's hard drive.
Выберете то, что вам нужно
On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
Navigate the XMB to the 'Settings' menu and select 'System Settings'
Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
Use the flat end of a spudger to pry the hard drive door away from the lower case.
Remove the hard drive door from the PS3.
Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
Grab the hard drive pull tab and pull the hard drive toward the front face of the PS3.
Pull the hard drive assembly out of the PS3.
Инструмент, используемый на этом этапе:Screw Extracting Pliers$19.99
Remove the four 4.3 mm Phillips screws securing the hard drive cage to the hard drive.
157 участников успешно повторили данное руководство.
16 Комментариев
Hi there!
Thank you for this (and all the other) guide!
My Hard Drive Slot looks a little bit different.
You have to spudge away the door from the left side and after removing the Blue Screw you can easily pull out the harddrive and you don't have to slide the tray to the side and out afterwards.
Maybe worth a note that there are several versions around..
Nice explenatory guide!
My playstation3 fell over" lost all my icons on screen. I took it in to see what's wrong, they say I need to replace hard drive. Were can I buy a hard drive and how much does it cost? Can I do it myself? Please give me some answers or tips
if you can’t figure that out you should stop gaming…
You can find a new hard drive on Amazon. Data's gone, though.
