Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
Pull the ribbon cable out of its socket.
Remove the Blu-ray drive from the PS3.
Pull the control board ribbon cable straight up and out of its socket on the motherboard.
Remove the two 12 mm Phillips screws securing the control board to the lower case.
Remove the control board and its attached cable from the PS3.
Remove the following eight screws securing the motherboard assembly to the lower case:
Seven 12 mm Phillips screws (ph2)
Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
Remove the hard drive bay cover.
Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
De-route the fan cables from the plastic finger molded into the heat sink.
Disconnect the fan from the motherboard.
Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
Lift the memory card reader out of the PS3 enough to access its ribbon cable.
Flip up the retaining flap on the memory card reader ribbon cable socket.
Pull the ribbon cable out of its socket and remove the memory card reader.
Disconnect the DC-In cables from the front of the heat sink.
Remove the five 9 mm Phillips screws securing the power supply to the chassis.
Lift the power supply by its front edge to clear the two posts attached to the motherboard.
Remove the power supply.
Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
Remove the two brackets held under the screws you just removed.
Lift the motherboard assembly off the heat sink.
Be sure to apply a new layer of thermal paste when reattaching the heat sink.
Remove the three 5.7 mm #0 Phillips screws securing the fan to the heat sink.
Remove the fan from the heat sink, minding its cables that may get caught.
53 участников успешно повторили данное руководство.
7 Комментариев
i make thermal compounds. just wondering do i need to use a grease that has silver or is an aluminum based grease good to use
Thanks a lot! It is very useful!
I know this is old but what thermal paste should I use today
I recommend artic silver or MX-4 since I heard that it's supposed to last up to 8 years. As long as you don't have to disassemble the console again
