PlayStation 3 Lower Case Replacement
Выберете то, что вам нужно
  1. PlayStation 3 Lower Case Replacement, Smart Plate: шаг 1, изображение 1 из 2 PlayStation 3 Lower Case Replacement, Smart Plate: шаг 1, изображение 2 из 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Lower Case Replacement: шаг 2, изображение 1 из 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Lower Case Replacement: шаг 3, изображение 1 из 3 PlayStation 3 Lower Case Replacement: шаг 3, изображение 2 из 3 PlayStation 3 Lower Case Replacement: шаг 3, изображение 3 из 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Lower Case Replacement: шаг 4, изображение 1 из 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Lower Case Replacement, Top Cover: шаг 5, изображение 1 из 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Lower Case Replacement: шаг 6, изображение 1 из 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Lower Case Replacement, Blu-ray Disc Drive: шаг 7, изображение 1 из 1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Lower Case Replacement: шаг 8, изображение 1 из 1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Lower Case Replacement: шаг 9, изображение 1 из 3 PlayStation 3 Lower Case Replacement: шаг 9, изображение 2 из 3 PlayStation 3 Lower Case Replacement: шаг 9, изображение 3 из 3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 Lower Case Replacement, Motherboard Assembly: шаг 10, изображение 1 из 1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 Lower Case Replacement: шаг 11, изображение 1 из 2 PlayStation 3 Lower Case Replacement: шаг 11, изображение 2 из 2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 Lower Case Replacement: шаг 12, изображение 1 из 1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 Lower Case Replacement: шаг 13, изображение 1 из 1
    • Remove the control board bracket.
  14. PlayStation 3 Lower Case Replacement: шаг 14, изображение 1 из 2 PlayStation 3 Lower Case Replacement: шаг 14, изображение 2 из 2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 Lower Case Replacement: шаг 15, изображение 1 из 1
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 Lower Case Replacement, Lower Case: шаг 16, изображение 1 из 1
    • Lower case remains.
Заключение
12 участников успешно повторили данное руководство.
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 46
За всё время: 17,933
