Введение
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
More info about disassembling, you can find in
Выберете то, что вам нужно
Видео обзор
Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
To remove the power supply, first disconnect the two cables, then the 2 Phillips screws. Then lift it upwards.
For the 2-cables model, remove the two very small phillips screws in each lower corner referenced by the red circles.
For the 4-cables model, remove the small Phillips screw in the bottom left corner referenced by the red circle.
Carefully remove the plastic shell, paying attention to the cable that runs through it for the 4-cables model.
Remove the 4 Phillips screws at each corner of the laser mechanism.
Then remove the mechanism.
What is the part number for the 4 screws that secure the laser deck and also the part number for the 4 rubber shock absorbers where the screws go into?
You can test the console before full assembling.
To do this, reassemble the blu-ray drive, reconnect its cables, and reconnect the power supply.
16 участников успешно повторили данное руководство.
Один комментарий
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
What is the part number for the plastic caps that hide the screws?
There's rubber caps and plastic caps that you have to remove to access the screws.
Byron Arriola - Ответить
Model 2504B : You have to remove the hard drive first in order to remove the case.
Stephane Dannebey - Ответить
