Введение
You can use this method if you can't eject the stuck disk by the eject button and the eject hole. The PS3 slim on this video is model CECH-300X.
Full video you can see here:
More info about disassembling, you can find in PlayStation 3 Slim Teardown
Запчасти
Детали не указаны.
Видео обзор
  1. PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk, PlayStation 3 Slim - Manually Removing Stuck Disk: step 1, image 3 of 3
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 2, image 3 of 3
    • Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side.
  3. PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 1 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 2 of 3 PlayStation 3 Slim - Manually Removing Stuck Disk: step 3, image 3 of 3
    • First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside.
  4. PlayStation 3 Slim - Manually Removing Stuck Disk: step 4, image 1 of 2 PlayStation 3 Slim - Manually Removing Stuck Disk: step 4, image 2 of 2
    • In this case we have ... 4x disks. :)
    • Did you do it successfully?
  5. PlayStation 3 Slim - Manually Removing Stuck Disk: step 5, image 1 of 2 PlayStation 3 Slim - Manually Removing Stuck Disk: step 5, image 2 of 2
    • Test the console before assembling. And don't forget to put the spindle disc magnet.
Заключение
16 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
184 917 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
307 членов
Автор 1 119 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 46
За последние 30 дней: 229
За всё время: 21,343
