PlayStation 3 Slim Control Board Replacement
Выберете то, что вам нужно
  1. PlayStation 3 Slim Control Board Replacement, Top Cover: шаг 1, изображение 1 из 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Control Board Replacement: шаг 2, изображение 1 из 2 PlayStation 3 Slim Control Board Replacement: шаг 2, изображение 2 из 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Control Board Replacement: шаг 3, изображение 1 из 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Control Board Replacement: шаг 4, изображение 1 из 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Control Board Replacement: шаг 5, изображение 1 из 2 PlayStation 3 Slim Control Board Replacement: шаг 5, изображение 2 из 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Control Board Replacement, Control Board: шаг 6, изображение 1 из 2 PlayStation 3 Slim Control Board Replacement, Control Board: шаг 6, изображение 2 из 2
    • Use the tip of a spudger to pry the control board out of its housing within the lower case.
    • Pull the control board ribbon cable away from its socket on the control board.
Заключение
21 участников успешно повторили данное руководство.
2 Комментариев
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
wrestlemaniafreak - Ответить
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 38
За последние 30 дней: 122
За всё время: 26,156
