Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Turn the PS3 over and lay it on its backside. Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  3. Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  4. Using its attached metal handle, pull the hard drive out of its bay. Using its attached metal handle, pull the hard drive out of its bay.
    • Using its attached metal handle, pull the hard drive out of its bay.
Заключение
3 участников успешно повторили данное руководство.
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,044
